20 years agoDownload But Verify Failed
Hi All, I am using Nios Dev Board with MT48LC2M32B2 SDRAM(It is the only execute memory). When I make a software example and download it to sdram, it displays in nios IDE console: <div class='qu...
20 years agoThere is an Altera provided document explaining the SDRAM core which also provides a calculation (at the very end) for the clock phase shift required:
sdram controller (http://www.altera.com/literature/hb/nios2/n2cpu_nii51005.pdf#) Hope that helps. I'm having the same problems and I'm trying various phase shifts...
