16 years agoDouble precision floating point math problem with NiosII/e
I'm planning to use budget NiosII/e, provided by SOPC with Cyclone III. I wrote a simple program, to check if its double floating point math works correctly: #include <stdio.h> #includ...
16 years agoCheck the objdump file and look at the floating point operators to see if hardware is being called (you should see the instruction "custom" instead of a software library call if the hardware is being used). It almost appears like somehow single precision hardware is being used for double precision operators which shouldn't be the case.
