16 years agoDouble precision floating point math problem with NiosII/e
I'm planning to use budget NiosII/e, provided by SOPC with Cyclone III. I wrote a simple program, to check if its double floating point math works correctly: #include <stdio.h> #includ...
16 years agoHello,
You can find some answers in the tutorial "Using Nios II Floating-Point Custom Instructions" (http://www.altera.com/literature/tt/tt_floating_point_custom_instructions.pdf (http://www.altera.com/literature/tt/tt_floating_point_custom_instructions.pdf%29)). "The floating-point custom instructions, implement single precision floating-point arithmetic operations." So you cannot use floating point hardware for double precision calculation, whatever the type of processor (e/s/f). For your case 3, I agree that if you disable it with pragma directives it should use software implementation as in case 1, but I don't know the second pragma directives you use (which finished with a 'd'), where do you find them. On the tutorial they put only the first ones (which finished with a 's'). Jérôme
