16 years agoDoes the Nois ii processor support DVFS(dynamic frequency and voltage scaling)?
Hi, :p I am doing research about power management.Now I want to create a distributed system envinronment using Nois ii on Cyclone iii. But my question is " Does the Nois ii processor sup...
13 years agoFPGAs are not at all comparable to DSPs or other processors on the power utilization grounds because of the parallelism. And I have also worked on FPGAs for my image processing project, you can only change the frequency and not the voltage. You need to add extra circuitry manually on your board if you want to change voltage during runtime in your program.
