20 years agoDoes Nios II Linux v1.4 support StratixII(EP2S30)?
Dear all: Would you please tell me if i can run Nios II Linux v1.4 on my Nios II Development Kit, Stratix II Edition? thanks Best regards.
20 years agoIt should, but there is a little problem...
The FPGA required to be programmed in order to access the flash memory. This is usually where the kernel and filesystem will go. However, V1.4 doesn't package with sof file for EP2S30 (can be found in C:\altera\kits\nios2\components). If the source files are in this directory, you can recompile, but there are no where to be found! I am having the same problem with EP2S60. My problem is the pre-package is EP2S60ES! I have spoken to someone at Altera about my problem. SM
