my board is a altera dev board!
could you tell me how to do step by step? thank you ! and i want to know your ID ! - Altera_Forum
--- Quote Start --- originally posted by iriver@Apr 14 2006, 07:24 PM my board is a altera dev board!could you tell me how to do step by step?
thank you !
and i want to know your id !
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14370)
--- quote end ---
--- Quote End --- sorry, I don't use i phone or msn. Many people have the 2C35 dev board, and run uClinux successfully. First, can you find the zImage file in nios2 SDK shell ? check step6 in the guide again and try "ls" .
--- Quote Start --- originally posted by iriver@Apr 12 2006, 08:59 AM yes,i follow the linux quick start guide!when i run the linux project,
and i find this appear :downloading to 0x0400000( my ram base) ...%
is the linux downloaded into ram?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14261)
--- quote end ---
--- Quote End --- Oh no, It was misleading ! I didn't want you to follow microtronix's "linux quick start guide" ! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif I wanted you follow my buildroot guide and work on Linux PC. http://forum.niosforum.com/forum/index.php?showtopic=3174 (http://forum.niosforum.com/forum/index.php?showtopic=3174) If you can read Chinese, there is a translated. how to run the uClinux in NIOS2 in Chinese by Alex.liu. http://www.icwin.net/showartitle.asp?art_id=8313&cat_id=52 (http://www.icwin.net/showartitle.asp?art_id=8313&cat_id=52)
to hippo:
could you tell me how to run linux on ep2c35 according to the linux quick start guide? you tell me to use your build guide on linux! i try it on my vitual linux machine,but mang errors occured! why? i can not understand your builde guide,can you explain it exactly! did you sucess in running the linux on ep2c35? how i can get in touch with you by chinese? thank you!! - Altera_Forum
when i run linux on ep2c35,the below happen:
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: not responding. Resetting and trying again: OK Downloading 01000000 ( 0%) Downloading 01010000 ( 6%) Downloading 01020000 (13%) Downloading 01030000 (20%) Downloading 01040000 (27%) Downloading 01050000 (33%) Downloading 01060000 (40%) Downloading 01070000 (47%) Downloading 01080000 (54%) Downloading 01090000 (60%) Downloading 010A0000 (67%) Downloading 010B0000 (74%) Downloading 010C0000 (81%) Downloading 010C47C0 (82%) Downloading 010D0000 (87%) Downloading 010E0000 (94%) Downloaded 948KB in 16.2s (58.5KB/s) Verifying 01000000 ( 0%) Verify failed between address 0x1000000 and 0x100FFFF Leaving target processor paused why??? - Altera_Forum
--- Quote Start --- originally posted by iriver@Apr 19 2006, 09:21 PM when i run linux on ep2c35,the below happen:using cable "usb-blaster [usb-0]", device 1, instance 0x00
pausing target processor: not responding.
resetting and trying again: ok
downloading 01000000 ( 0%)
downloading 01010000 ( 6%)
downloading 01020000 (13%)
downloading 01030000 (20%)
downloading 01040000 (27%)
downloading 01050000 (33%)
downloading 01060000 (40%)
downloading 01070000 (47%)
downloading 01080000 (54%)
downloading 01090000 (60%)
downloading 010a0000 (67%)
downloading 010b0000 (74%)
downloading 010c0000 (81%)
downloading 010c47c0 (82%)
downloading 010d0000 (87%)
downloading 010e0000 (94%)
downloaded 948kb in 16.2s (58.5kb/s)
verifying 01000000 ( 0%)
verify failed between address 0x1000000 and 0x100ffff
leaving target processor paused
why???
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14481)
--- quote end ---
--- Quote End --- which quartus and nios2 version do you use? what command do you use to download?
i use the 5.1,and download with the ide
--- Quote Start --- originally posted by iriver@Apr 20 2006, 11:21 AM i use the 5.1,and download with the ide<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14494)
--- quote end ---
--- Quote End --- Do it in a nios2 sdk shell. Did you setup the tools and build kernel on Linux?
NO! I build kernel with ide on windows
can it do ? - Altera_Forum
--- Quote Start --- originally posted by iriver@Apr 20 2006, 01:24 PM no! i build kernel with ide on windowscan it do ?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14497)
--- quote end ---
--- Quote End --- Sorry, I won't support it. It is known to have a lot of trouble. I recommand working on Linux. It is important that you learn Linux before you use nios2 uClinux.
