19 years ago
Does Nios II Linux v1.4 support EP2c35?
thank you!
    The Microtronix Linux Plugin only works with Nios 5.0 IDE if you use 5.1 then you get the error message that the programmer has been updated.
    You can use 5.1 but you must upload the Kernel and Filesystem from the commandline.
    Use these commands in the nios2-terminal:
    >>We currently do not support Nios II Linux with Quartus II v5.1
    >>In the interim, the kernel and filesystem projects can be uploaded manually >>from the command line using the following procedure:
    >>Upload the .sof file for your hardware design first, then run the following >>commands.
    [SOPC Builder]$ cd $ECLIPSE_WORKSPACE/<project>/build
    [SOPC Builder]$ nios2-elf-objcopy -O binary vmlinux vmlinux.bin
    [SOPC Builder]$ bin2flash --location=0x0 --input=vmlinux.bin --output=vmlinux.flash
    [SOPC Builder]$ nios2-flash-programmer --base=0x800000 vmlinux.flash
    to nacide:
    if i run the linux on ram,not download into flash,will it work?
    if it can do,what i should do?
    thank you!
    when i run linux on DE2,it happaens:
    Linux version 2.6.11-uc0 (ty@ty024) (gcc version 3.4.1 (Altera Nios II 5.1 b73))
    # 2 Thu Apr 27 20:24:19 2006
    on
    .4.1 (AlteNios II
    I 5.1 b73))# 2 Thpport © 2004 Microtronix Datacom Ltd.
    s ilt 1 zonelists
    I support ©d line: root=/dev/mtdblock0 ro
    BuD hash table entries: 64 (order: 6, 1024 bytes)
    tdblock0 ro
    PIsh table entries: 2048 (order: 1, 8192 bytes)
    Dentry cache hatable entries: 1024 (order: 0, 4096 bytes)
    Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
    288k data)
    ble: 6372k/8192k RAM, 0k/0k ROM (1412k kernel code, 288k data)
    Registered protocol family 16
    512 (order: 0, 4096 bytes)
    NET: Registered protocol family 16
    000ial: JTAG UART driver $Revision: 1.4 $
    ttyJ0 at MMIO 0x81004cheduler anticipatory registered scheduler noop registered
    io sededuler anticipatory registered
    io scheduler deadline registered
    io scheduler cfq registered
    ksize
    driver initialized: 16 RAM disks of 4096K size 1024 blocksize
    tera NDK flash (AMD): Found 1 x16 devices at 0x0 in 8-bit bankps: 1
    Fujitsu Extended Query Table at 0x0040
    number of CFI chips: 1
    cfi_cmdset_0002: Disabling erase-susing not available
    code brokenness.
    cmdlinepart partition parsing not available
    RedBoot partition parsing not available
    Usin"Altera NDK flash (AMD)":
    nition
    Creating 4 MTD partitions on "Altera NDK flash (AMD)":
    s2" extends beyond the end of device "Altera NDK flash (AMD)" -- size truncated
    to 0x200000
    device "Altera NDK flash (AMD)" --nel"
    truncated to 0x200000
    0x00000000-0x00200000 : "loader/kernel"
    er configuration" is out of reach -- disabled
    td: partition "User configuration" is out of reach -- disabled
    fe configuration" is out of reach -- disabled
    td: partition "safe configuration" is out of reach -- disabled
    NET: Registered protocol family 2
    ished hash table entries: 512 (order: 0, 4096 bytes)
    TCP establash table entries: 512 (order: -1, 2048 bytes)
    tes)
    TCP bind h configured (established 512 bind 512)
    bytes)
    TCP: Hash tables family 1
    NET: Registered protocol family 17
    ios II 5.1 b73))# 2 Thu Apr 27 20:24:19 2006
    on
    .4.1 (AlteNios II
    suilt 1 zonelists
    I support © line: root=/dev/mtdblock0 ro
    BID hash table entries: 128 (order: 7, 2048 bytes)
    dblock0 ro
    Phash table entries: 4096 (order: 2, 16384 bytes)
    Dentry cache sh table entries: 2048 (order: 1, 8192 bytes)
    Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
    288k data)
    ble: 6360k/8192k RAM, 0k/0k ROM (1412k kernel code, 288k data)
    el panic - not syncing: Can&#39;t create rootfs
    , 4096 bytes)
    Kernel panic - not syncing: Can&#39;t create rootfs
    does it mean to the linux work?
    when i build the linux on EP2C35 on my FC4(vmware)
    these errors occur:
    arch/nios2nommu/boot/Makefile:29: &#35686;&#21578;&#65306;&#35206;&#30422;&#20851;&#20110;&#30446;&#26631;“arch/nios2nommu/boot/zImage”&#30340;&#21629;&#20196;
    arch/nios2nommu/boot/Makefile:12: &#35686;&#21578;&#65306;&#24573;&#30053;&#20851;&#20110;&#30446;&#26631;“arch/nios2nommu/boot/zImage”&#30340;&#26087;&#21629;&#20196;
    arch/nios2nommu/boot/Makefile:33: &#35686;&#21578;&#65306;&#35206;&#30422;&#20851;&#20110;&#30446;&#26631;“arch/nios2nommu/boot/compressed/vmlinux”&#30340;&#21629;&#20196;
    arch/nios2nommu/boot/Makefile:16: &#35686;&#21578;&#65306;&#24573;&#30053;&#20851;&#20110;&#30446;&#26631;“arch/nios2nommu/boot/compressed/vmlinux”&#30340;&#26087;&#21629;&#20196;
    arch/nios2nommu/boot/compressed/Makefile:58: &#35686;&#21578;&#65306;&#35206;&#30422;&#20851;&#20110;&#30446;&#26631;“arch/nios2nommu/boot/compressed/vmlinux”&#30340;&#21629;&#20196;
    arch/nios2nommu/boot/compressed/Makefile:22: &#35686;&#21578;&#65306;&#24573;&#30053;&#20851;&#20110;&#30446;&#26631;“arch/nios2nommu/boot/compressed/vmlinux”&#30340;&#26087;&#21629; &#20196;
    arch/nios2nommu/boot/compressed/Makefile:62: &#35686;&#21578;&#65306;&#35206;&#30422;&#20851;&#20110;&#30446;&#26631;“arch/nios2nommu/boot/compressed/vmlinux.bin”&#30340; &#21629;&#20196;
    arch/nios2nommu/boot/compressed/Makefile:26: &#35686;&#21578;&#65306;&#24573;&#30053;&#20851;&#20110;&#30446;&#26631;“arch/nios2nommu/boot/compressed/vmlinux.bin”&#30340; &#26087;&#21629;&#20196;
    arch/nios2nommu/boot/compressed/Makefile:65: &#35686;&#21578;&#65306;&#35206;&#30422;&#20851;&#20110;&#30446;&#26631;“arch/nios2nommu/boot/compressed/vmlinux.bin.gz”&#30340;&#21629;&#20196;
    arch/nios2nommu/boot/compressed/Makefile:29: &#35686;&#21578;&#65306;&#24573;&#30053;&#20851;&#20110;&#30446;&#26631;“arch/nios2nommu/boot/compressed/vmlinux.bin.gz”&#30340;&#26087;&#21629;&#20196;
    arch/nios2nommu/boot/compressed/Makefile:72: &#35686;&#21578;&#65306;&#35206;&#30422;&#20851;&#20110;&#30446;&#26631;“arch/nios2nommu/boot/compressed/piggy.o”&#30340;&#21629;&#20196;
    arch/nios2nommu/boot/compressed/Makefile:36: &#35686;&#21578;&#65306;&#24573;&#30053;&#20851;&#20110;&#30446;&#26631;“arch/nios2nommu/boot/compressed/piggy.o”&#30340;&#26087;&#21629; &#20196;
    AS arch/nios2nommu/boot/compressed/head.o
    arch/nios2nommu/boot/compressed/head.S: Assembler messages:
    arch/nios2nommu/boot/compressed/head.S:111: Error: symbol `_start&#39; is already defined
    arch/nios2nommu/boot/compressed/head.S:117: Error: symbol `text_init&#39; is already defined
    arch/nios2nommu/boot/compressed/head.S:126: Error: symbol `data_init&#39; is already defined
    arch/nios2nommu/boot/compressed/head.S:146: Error: symbol `flush_cache&#39; is already defined
    arch/nios2nommu/boot/compressed/head.S:151: Error: symbol `data_flush&#39; is already defined
    arch/nios2nommu/boot/compressed/head.S:158: Error: symbol `text_flush&#39; is already defined
    arch/nios2nommu/boot/compressed/head.S:169: Error: symbol `fake_headers_as_bzImage&#39; is already defined
    make[2]: *** [arch/nios2nommu/boot/compressed/head.o] &#38169;&#35823; 1
    make[1]: *** [arch/nios2nommu/boot/compressed/vmlinux] &#38169;&#35823; 2
    why?
    thanks!!
    to hippo
    remove the old kernel tree ?you mean the linux-2.6.x tree?
    could you tell me how i change it exactly ?
    thank you !
    --- Quote Start ---
    originally posted by iriver@Jun 4 2006, 10:44 AM
    to hippo
    thank you !
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15852)
    --- quote end ---
    --- Quote End ---
    Please follow the new wiki, it is easier.
