21 years agoDoes Nios II custom instruction need clk_enable?
Hi all!!! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/rolleyes.gif I have a Nios II project with 3 custom instructions that export the signals to a shared user logic, out of...
21 years agoTill now, I never saw the clockenable going low on my system. So I just ingnore the input.
I think if you provide different custom instructions (with a defined nr), Altera generates the Mux logic. If you use only one custom instruction, you provide the mux (using the (N[7:0] signals). I can not see ignoring the clock enable can do any harm. The system (or you in the second case) will decide to use the result or not. stefaan
