21 years agoDoes MoreThanIP Core in uClinux1.3 need license?
Hello, When install the uClinux V1.3, there has MoreThanIP installed. But when I compile the system module, the error appears in the console. It says mtip_avalon_10_100_mac.edf need license f...
21 years agoHello,
Yes, the MTIP does require a license if you plan to do more than use the core that ships with the kit. An evaluation version ships with our uKit and Altera's Nios II Evaluation Kit. There are two options for 10/100 Ethernet - license the MTIP core (www.morethanip.com for more info) or you can also look at our OpenCores.org EMAC kit. more information is available here. (http://www.microtronix.com/product_ocmac.htm) Regards, Robert Microtronix
