20 years agodoes EPCS controller support DMA
I would like to know if the EPCS controller is able to handle DMA transfer. I would like to transfer NIOS2 code from EPCS to SDRAM using DMA at boot time, in order to boot as fast as possible. ...
20 years ago --- Quote Start --- originally posted by bigboss25@Jun 29 2006, 07:34 PM i would like to know if the epcs controller is able to handle dma transfer.
i would like to transfer nios2 code from epcs to sdram using dma at boot time, in order to boot as fast as possible.
i think that currently, if i'm not wrong, there is a firmware code (so the cpu) which handle this job. any idea ?
thanx all http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/smile.gif
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16523)
--- quote end ---
--- Quote End --- The max clock rate of epcs is 40MHz. So the data rate is less than 5MB/s. With a proper boot code, the data rate can be handle well with PIO. There will be little gain in using DMA.
