21 years agoDoes a NIOS II need reset?
Folks, I recently began porting my NIOS II design to its final hardware platform from the 1C20 eval board. During this effort, I eliminated reset by assigning it internally to '0'. My ...
21 years ago> how can I make it in a counter (flip-flops) without any problems then?
There's really no substitute for a good external reset ;-) However, I do use the pll locked signal as an enable/clear input to a reset counter that controls reset to a specific logic block. The counter's clock input is an external clock signal, _not_ the output of the pll. And the counter width is set based on the phase lock period from simulation (in my case about 16x the counter's input clock). So, the counter is simply trying to guarantee the stability of the pll locked signal before negating reset. I haven't had any problems ... yet. But to be honest, I'm not particularly comfortable with it either -- my knowledge just doesn't run deep enough at this point 8-( Given the number of posts to this topic -- an application note from the experts would be a welcomed reference.
