21 years agoDoes a NIOS II need reset?
Folks, I recently began porting my NIOS II design to its final hardware platform from the 1C20 eval board. During this effort, I eliminated reset by assigning it internally to '0'. My ...
21 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- The locked signal will toggle prior to actual phase lock -- this can cause some problems ;-) I still use a delay (along with the pll lock) to drive reset.[/b] --- Quote End --- This is not what I suspect from a pin named 'locked'. Was an other name better then?
