20 years agoDocumentation for C compiler/linker
Is there a good documentation available for Nios II compiler/linker tools, including section elaborating on details of floating point emulation library ? BTW - I am quite surprised the compile...
20 years agoAll of the documentation, that you're interested in, can be browsed to from within the IDE (from the Help menu) or you can just point your browser at:
<nios2_install>/documents/index.htm For the specific questions you have: 1. Yes, the compiler supports C++. - Ecos is written using C++ and it is ported to Nios II and uses the identical GCC toolchain. - Be sure that your C++ code has a file extension of .cpp [perhaps, other extensions will work as well?] or (I think) the IDE won't handle it correctly. 2. The floating point library details can likely be found in the documentation on newlib. Best of luck, - slacker
