12 years ago
do not have device option for upload kernel
in ubuntu
in uclinux_dist directory
make vendor_hwselect SYSPTF=/usr/local/src/nios_system.ptf
first time type this command, do not connect blast usb of DE2-115 board when i do not know need it
when i meet this option, i plug in the blast usb and select this usb in virtual box
and run above command again, it still do not have this option
then i make clean and run the above command again, it still do not have this option
do i need to make menuconfig again and run above command again?
do i need to install quartus 14 which i failed to install ?
do not have cfi_flash_0 which listed in tutorial example web
--- Please select which CPU you wish to build the kernel against:
(1) cpu_0 - Class: altera_nios2 Type: f Version: 7.071
Selection: 1
--- Please select a device to upload the kernel to:
(1) cfi_flash_0
Class: altera_avalon_cfi_flash
