21 years agoDMA transfer
I copied an example from the Altera Nios II Software Developer’s Handbook, chapter "Using DMA Devices" using memory to memory data transfer. I modified the code a bit ..... The good thing is th...
21 years agoI use the same kit, and using web edition 4.2 of QII.
Perhaps the problem has something to do with the SoPC design ? I have added a dma channel called dma_0 to the example project "my-first-nios". You too? PS: is it possible to add an attachment to this reply perhap I could sent the design to you.....
