21 years agoDMA transfer
I copied an example from the Altera Nios II Software Developer’s Handbook, chapter "Using DMA Devices" using memory to memory data transfer. I modified the code a bit ..... The good thing is th...
21 years agoI've just tried to run your code on the 1C20 full design from the Nios II 1.1 kit. That worked fine. What hardware/version of the kit are you using?
