14 years agoDMA Transfer problem
Hi, I am trying to do a simple DMA mem to mem transfer as per the "Chap24: DMA controller core " example. I have been at this for almost a week now and it is still not working for me. Can you p...
14 years agoYou could create a linker section in those locations that prevent the linker from placing any sections in there. The lazy way to test this would be to dynamically allocate those two buffers using a malloc to ensure the linker doesn't put anything there. You can't pick a location that could potentially be used by the processor at run time without ensuring precautions are taken. So it's possible that your code is stomping on itself and causing things to go off in the weeds.
