21 years agoDMA transfer problem
Hi, i'm working on my design with NiosII , two sdram controller , 3 dma and some other peripheral.
Now all hardware and software seem working fine, except DMA. The program is working correctly from flash to Dram , where i can write and read on each dram controller without difficulty. I have a lot of problem when i try to use the DMA, i'm using it directly with IOWR functions, i have cecked the contenents of DMA register in assembly and it's OK. (read and write are 32bit size) When i use the dma i find on destination buffer for example only 24 bytes istead the 4096 requested........, the dram tsu and tco seem correct, in any case i try to reduce the system speed from 100 to 80 and after to 50 MHz, but with same result. I cechk all topic about the dma in this forum, but i don't find any idea. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/dry.gif http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/dry.gif any suggestion welcome........1 Reply
Hi Roberto,
I would use the HAL implementation instead of IOWRs directly, the HAL works fine for DMA. Also, I would, if you have modelsim, do a functional simulation to see what your DMA tranactions are doing. -Baycool
