21 years agoDMA transfer length problem
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif There is a problem in transferring data from SDRAM to my device ( avalon slave device ) . I use the DMA component p...
21 years agoI have next assume.
Maybe your device sets "endofpacket" signal before ending of transferring. In this case disable bit REEN or WEEN, it depends on a direction or transferring. Other case there is an increment of write address. Disable WCON in this case. I hope it helps you http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
