16 years agoDMA transfer inside ISR: Problem
Hi everybody, I think this is a common issue, but I didn't find a solution to my question, so hopefully I will get an answer here: I have a DMA controller which I want to use on an IRQ com...
15 years ago --- Quote Start --- No, I don't forget to set I_EN. I don't enable the IRQ because I'll not use a ISR routine in my project to transmit the data from DMA to UART. --- Quote End --- Oh, sorry I forgot!:-) --- Quote Start --- Which version of Quartus and Nios EDS do you use? --- Quote End --- I use Quartus 10.0 and NIOS EDS 10.0. Both with SP1. It's really strange that you get almost correct transfer though you are using (in my opinion) the wrong address of the TXDATA register of the UART. Hmmm? No Idea yet. Sorry... Maybe you should use SignalTap for debugging. It helped us a lot! Really amazing tool. Regards
