16 years agoDMA transfer inside ISR: Problem
Hi everybody, I think this is a common issue, but I didn't find a solution to my question, so hopefully I will get an answer here: I have a DMA controller which I want to use on an IRQ com...
15 years agoHi!
No, I don't forget to set I_EN. I don't enable the IRQ because I'll not use a ISR routine in my project to transmit the data from DMA to UART. Which version of Quartus and Nios EDS do you use? Tomorrow I will install Quartus 10 and Nios EDS and I will recompile the project in the new version (now I used the 9.1 sp2). I hope that it’s a compiler error…. Thanks for your help!
