16 years agoDMA transfer inside ISR: Problem
Hi everybody, I think this is a common issue, but I didn't find a solution to my question, so hopefully I will get an answer here: I have a DMA controller which I want to use on an IRQ com...
15 years agoHi! Thank you so much for your fast response!
Yes, in my system I have a processor NiosII/f with data and istruction cache (look the attachment). In my system I use an external SRAM and a little on_chip_memory (4096 Bytes) which is used also for exception vector. If I read the address of buffer it seems that it's always allocated in external SRAM in all previous cases. How can I bypass the cache and read the values direct from the ram?! Thanks for your help! (http://www.answerbag.com/q_view/1182695#ixzz13xxzrkvj)
