20 years agoDMA SDRAM burst read not working
I just posted this as a support service request... We are using a SOPC Builder-instantiated DMA controller to interface between the SDRAM and a small on-chip cache of 1600 bytes. The DMA is co...
20 years ago --- Quote Start --- originally posted by rhaikh@Mar 17 2006, 11:36 AM the exact same configuration works in other designs: it used to work on this board, and it continues to work on the devkit. you're right though, it is problematic.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13540)
--- quote end ---
--- Quote End --- It is not problematic if you would written your sdram controller with support burst read and write. opencores.org has similar sdram controller. It has burst mode and mode - "keep row open". Last mode has extremely fast access to sdram. Of course, if access is in one row only.
