16 years agoDMA problem
Hi, I'm transfering data (video frames) from sdram to component i build (using sopc component editor) by DMA controller. For each transaction the DMA transfers one frame line, data is then se...
16 years agoHi,
I don't know what is CVI. If you want to get the eop status you can read the DMA status register. you can use IORD_ALTERA_AVALON_DMA_STATUS(base). don't forget to include "altera_avalon_dma_regs.h" hope this helps
