16 years agoDMA problem
Hi, I'm transfering data (video frames) from sdram to component i build (using sopc component editor) by DMA controller. For each transaction the DMA transfers one frame line, data is then se...
16 years agoThank you very much for your response, i was off the forum for a while...
I solved the DMA problem using "readyfordata" signal and correct timing.
