21 years agodma_mapping.h stubs
I am trying to build a kernel with support for SL811, but I am having trouble defining the stubs for dma_mapping.h I have checked the other threads in this forum, but there are no explicit exam...
21 years agoadd the following to asm/dma_mapping.h:
static inline dma_addr_t
dma_map_single(struct device *dev, void *cpu_addr, size_t size,
enum dma_data_direction dir)
cache_push ((unsigned long)cpu_addr, size);
return virt_to_bus((unsigned long)cpu_addr);
* dma_unmap_single - unmap a single buffer previously mapped
* @dev: valid struct device pointer, or NULL for ISA and EISA-like devices
* @handle: DMA address of buffer
* @size: size of buffer to map
* @dir: DMA transfer direction
* Unmap a single streaming mode DMA translation. The handle and size
* must match what was provided in the previous dma_map_single() call.
* All other usages are undefined.
* After this call, reads by the CPU to the buffer are guaranteed to see
* whatever the device wrote there.
static inline void
dma_unmap_single(struct device *dev, dma_addr_t handle, size_t size,
cache_clear((unsigned long)bus_to_virt(handle), size);
* dma_map_sg - map a set of SG buffers for streaming mode DMA
* @sg: list of buffers
* @nents: number of buffers to map
* Map a set of buffers described by scatterlist in streaming
* mode for DMA. This is the scatter-gather version of the
* above dma_map_single interface. Here the scatter gather list
* elements are each tagged with the appropriate dma address
* and length. They are obtained via sg_dma_{address,length}(SG).
* NOTE: An implementation may be able to use a smaller number of
* DMA address/length pairs than there are SG table elements.
* (for example via virtual mapping capabilities)
* The routine returns the number of addr/length pairs actually
* used, at most nents.
* Device ownership issues as mentioned above for dma_map_single are
* the same here.
static inline int
dma_map_sg(struct device *dev, struct scatterlist *sg, int nents,
int i;
for (i = 0; i < nents; i++, sg++) {
char *virt;
sg->dma_address = page_to_bus(sg->page) + sg->offset;
virt = page_address(sg->page) + sg->offset;
cache_push ((unsigned long)virt, sg->length);
return nents;
* dma_unmap_sg - unmap a set of SG buffers mapped by dma_map_sg
* Unmap a set of streaming mode DMA translations.
* Again, CPU read rules concerning calls here are the same as for
* dma_unmap_single() above.
static inline void
dma_unmap_sg(struct device *dev, struct scatterlist *sg, int nents,
int i;
char *virt;
cache_clear ((unsigned long)virt, sg->length);
