21 years ago
dma_mapping.h stubs
I am trying to build a kernel with support for SL811, but I am having trouble defining the stubs for dma_mapping.h
I have checked the other threads in this forum, but there are no explicit examples of adding the dma stubs. Also, where should I add the stubs, include\nios2-nommu\dma_mapping.h ?
    add the following to asm/dma_mapping.h:
    static inline dma_addr_t
    dma_map_single(struct device *dev, void *cpu_addr, size_t size,
            enum dma_data_direction dir)
        cache_push ((unsigned long)cpu_addr, size);
        return virt_to_bus((unsigned long)cpu_addr);
     * dma_unmap_single - unmap a single buffer previously mapped
     * @dev: valid struct device pointer, or NULL for ISA and EISA-like devices
     * @handle: DMA address of buffer
     * @size: size of buffer to map
     * @dir: DMA transfer direction
     * Unmap a single streaming mode DMA translation.  The handle and size
     * must match what was provided in the previous dma_map_single() call.
     * All other usages are undefined.
     * After this call, reads by the CPU to the buffer are guaranteed to see
     * whatever the device wrote there.
    static inline void
    dma_unmap_single(struct device *dev, dma_addr_t handle, size_t size,
        cache_clear((unsigned long)bus_to_virt(handle), size);
     * dma_map_sg - map a set of SG buffers for streaming mode DMA
     * @sg: list of buffers
     * @nents: number of buffers to map
     * Map a set of buffers described by scatterlist in streaming
     * mode for DMA.  This is the scatter-gather version of the
     * above dma_map_single interface.  Here the scatter gather list
     * elements are each tagged with the appropriate dma address
     * and length.  They are obtained via sg_dma_{address,length}(SG).
     * NOTE: An implementation may be able to use a smaller number of
     *       DMA address/length pairs than there are SG table elements.
     *       (for example via virtual mapping capabilities)
     *       The routine returns the number of addr/length pairs actually
     *       used, at most nents.
     * Device ownership issues as mentioned above for dma_map_single are
     * the same here.
    static inline int
    dma_map_sg(struct device *dev, struct scatterlist *sg, int nents,
        int i;
        for (i = 0; i < nents; i++, sg++) {
      char *virt;
      sg->dma_address = page_to_bus(sg->page) + sg->offset;
      virt = page_address(sg->page) + sg->offset;
      cache_push ((unsigned long)virt, sg->length);
        return nents;
     * dma_unmap_sg - unmap a set of SG buffers mapped by dma_map_sg
     * Unmap a set of streaming mode DMA translations.
     * Again, CPU read rules concerning calls here are the same as for
     * dma_unmap_single() above.
    static inline void
    dma_unmap_sg(struct device *dev, struct scatterlist *sg, int nents,
        int i;
      char *virt;
      cache_clear ((unsigned long)virt, sg->length);
    Thanks Wentau.
    You will have to stay with me here. I am not too experienced with uClinux.
    First off, when you suggest adding to asm/dma-mapping.h , does the asm somehow get expanded to asm-nios2nommu ? I guessed this might be the case, so I added the code to asm-nios2nommu/dma-mapping.h
    Now I get a series of compilation warnings and errors, here&#39;s a snippet;
    include2/asm/dma-mapping.h: In function `dma_map_single&#39;:
    include2/asm/dma-mapping.h:30: warning: implicit declaration of function `cache_push&#39;
    include2/asm/dma-mapping.h:31: warning: implicit declaration of function `virt_to_bus&#39;
    include2/asm/dma-mapping.h: In function `dma_unmap_single&#39;:
    include2/asm/dma-mapping.h:52: warning: implicit declaration of function `cache_clear&#39;
    include2/asm/dma-mapping.h:52: warning: implicit declaration of function `bus_to_virt&#39;
    include2/asm/dma-mapping.h: At top level:
    include2/asm/dma-mapping.h:79: warning: "struct scatterlist" declared inside parameter list
    include2/asm/dma-mapping.h:79: warning: its scope is only this definition or declaration,
    Figuring that there must be an include file that I could reference for the undeclared functions, I did a grep on cache_clear, with no results.
    How do I reference these undeclared functions, and structures?
    Steve.
    Yes clansdown, they will be in the next release.
    Hi sfielding, yes I mean asm-nios2nommu/dma-mapping.h. Please add the following to the beginning of the file:
    #include <asm/scatterlist.h># include <linux/mm.h># include <asm/io.h># include <asm/cacheflush.h>
    You also need to add the following line to the file cacheflush.h in the same directory:
    extern void cache_clear (unsigned long paddr, int len);
