21 years agoDMA Controller
Does the DMA Controller support streaming byte datawidths from a peripheral to word datawidths for memory? In other words does it support the avalon bus capability of mixing the two bus sizes. Where ...
21 years agoI want the most efficient memory usage possible. So I'd like all the reads/writes to memory to use the full 32 bit datawidth. The problem is my peripheral has an 8bit databus. Initially I set the datawidth for the dma streaming to 8bit during testing and it worked fine. The main question was whether it would automatically buffer 4 bytes of those to maximize the memory efficiency. I don't want to waste memory cycles by only writing a byte during every cycle. I'd rather redesign the paripheral so that it would buffer 4 bytes and then do 32 bit transfers. Before I do that I wanted to make sure that it wasn't already being done automatically.
