21 years agoDMA Controller
Does the DMA Controller support streaming byte datawidths from a peripheral to word datawidths for memory? In other words does it support the avalon bus capability of mixing the two bus sizes. Where ...
21 years agojasonm,
I'm not completely sure I understand your question, but I'll take a stab at it: DMA transfers go at whatever data size is specified in the control register. If you read from a 32-bit SDRAM and write to an 8-bit peripheral (say, a UART), you'd set the control register BYTE bit, and both reads and writes would be done byte-by-byte. So, "In other words does it support the avalon bus capability of mixing the two bus sizes" - Yes. "Where it will buffer 4 bytes then does a single memory write" - No.
