16 years agoDMA burst data transfer
Hi I am working on DMA of Nios II , In SOPC builder i have set burst size of DMA as 128 words so i should be able to transfer 128 words or (128*4=512) bytes In Nios IDE i see i am ab...
16 years agoWell you are in luck, that is SDR SDRAM and the controller for that memory type is non bursting. So you do not need bursting at all so I recommend disabling burst support in the DMA and then you can transfer any memory to memory transaction you like.
