16 years agoDMA between Custom Component and SRAM
Hi folks, instead of describing what I try to do, I have uploaded my whole project which speaks for itself. Here I will just post the main project structure and the questions I have: The m...
16 years agoHi Kalyansrinivas,
thanks for your answer! Good to know, that the SOPC connections are correct. Have you had a look at the custom component VHDL code? I read that the DMA is only working if the components use flow control. I would be happy if somebody could confirm that my component provides a correct flow control interface. If you look in the folder "software" then you can see what code I used to test the system. It is mainly a DMA example from the NIOS II Software developer Handbook (or was it the Quartus II handbook, I can't remember right now . . .). Maybe somebody else can make annotations to this project if there are things that are heading into the wrong direction. @Kalyansrinivas: I will let you know if your hints helped me to get the system running. We have to wait until next week because I don't have the hardware available, right now. Thank you, Maik
