16 years agoDMA between Custom Component and SRAM
Hi folks, instead of describing what I try to do, I have uploaded my whole project which speaks for itself. Here I will just post the main project structure and the questions I have: The m...
16 years agoHi
1) The way you connected the dma in SOPC Builder is correct 2) You are reading data from a pheripheral so i think you need to use these alt_dma_rxchan_ioctl() & alt_dma_txchan_ioctl() functions ALT_DMA_SET_MODE_8, ALT_DMA_SET_MODE_16 for transferring as a byte or halfword to memory The destination address should be SRAM not Avalan tristate bridge I too want to know this ,So let me know the correction if you get the result regards Kalyansrinivas
