20 years agoDMA and Uart
hi ! i would like to start implement DMA controller with uart I already generate and download my system into fpga startix II dev board succefully . I saw also documents about DMA , bit into...
20 years agoI would use Signal Tap II on the interfaces (or simulate the system) so that you can see what is happening in the hardware. That should be a lot quicker than trying to guess your way through it.
