20 years agoDMA and Uart
hi ! i would like to start implement DMA controller with uart I already generate and download my system into fpga startix II dev board succefully . I saw also documents about DMA , bit into...
20 years agofor example i have to send this structure data do uart
typedef struct RS485{ float data1; float data2; int data3[10]; long data4; }mydata; with sizeof(mydata) i can know the lenght of datas to send but there is not addressof(...) function to know the address in memory of my data structure ; The function alt_dma_txchan receive differents arguments , i can put &mydata instead the address in memory , i will try but where i specifie the uart ? thanks walter ciao
