16 years agoDMA - memory to memory writing problem..
hi folks, i want to write data from one address to an other via dma like in the code below, problem is, it doesn't work. first i use the macros to set the addresses and the length and then i s...
16 years agoWe solved the problem. After checking the system in Quartus, we saw, that the SD-RAM we used wasn't directly connected with the CPU1. We use an Cyclon3 with 2 CPU and it seems, that this was the Problem. After adding an On-Chip-Memmory and using this, or changing the accessed memmory to S-RAM it worked. For anybody who try to work with DMA and also has some problems dealing with the code, here is our working example without HAL.
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#include "sys/alt_dma.h"
#include "system.h"
#include "altera_avalon_dma_regs.h"
#include "alt_types.h"
#include "sys/alt_irq.h"
static int dma_done=0,TX,RX;
static void doneDMA(void* context , alt_u32 id)
usleep(10);
dma_done++;
IOWR_ALTERA_AVALON_DMA_STATUS(DMA_RS485_BASE, 0);
int Init(void)
IOWR_ALTERA_AVALON_DMA_CONTROL(DMA_RS485_BASE,
ALTERA_AVALON_DMA_CONTROL_BYTE_MSK|
ALTERA_AVALON_DMA_CONTROL_LEEN_MSK|
ALTERA_AVALON_DMA_CONTROL_I_EN_MSK);
alt_irq_register(DMA_RS485_IRQ,(void*) NULL,doneDMA);
return 0;
void Transfer(int where,int from,int howmuch)
dma_done=0;
while ((IORD_ALTERA_AVALON_DMA_STATUS(DMA_RS485_BASE) &
ALTERA_AVALON_DMA_STATUS_BUSY_MSK));
IOWR_ALTERA_AVALON_DMA_LENGTH(DMA_RS485_BASE, howmuch);
IOWR_ALTERA_AVALON_DMA_RADDRESS(DMA_RS485_BASE,(int) from);
IOWR_ALTERA_AVALON_DMA_WADDRESS(DMA_RS485_BASE,(int) where);
ALTERA_AVALON_DMA_CONTROL_GO_MSK |
IORD_ALTERA_AVALON_DMA_CONTROL(DMA_RS485_BASE));
void MemInit(int base_addr,int len, int value)
int i;
for (i=0;i<len;i++)
IOWR_8DIRECT(base_addr,i,value);
int main(void)
MemInit((int)RX,0x10,3);
MemInit((int)TX,0x10,6);
Init();
Transfer((int)RX,(int)TX,16);
while(!dma_done);
return 0;
