16 years agoDMA - memory to memory writing problem..
hi folks,
i want to write data from one address to an other via dma like in the code below, problem is, it doesn't work. first i use the macros to set the addresses and the length and then i set the byte mask and the go mask. did i forget anything? thanks for your help ------------------
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#include "sys/alt_dma.h"
#include "system.h"
#include "altera_avalon_dma_regs.h"
/* Callback function that obtains notification that the data is received.*/
int
main (void)
int i=0;
char sMSG_tx,sMSG_rx;
memset(sMSG_rx,0,sizeof(sMSG_rx));
memset(sMSG_tx,0x55,sizeof(sMSG_tx));
for(i=0;i<8;i++)
printf("%d",sMSG_tx);
printf("\n");
for(i=0;i<8;i++)
printf("%d",sMSG_rx);
printf("\n");
/*initialize*/
IOWR_ALTERA_AVALON_DMA_RADDRESS(DMA_RS485_BASE,(
int) sMSG_tx);
IOWR_ALTERA_AVALON_DMA_WADDRESS(DMA_RS485_BASE, (int)sMSG_rx);
IOWR_ALTERA_AVALON_DMA_LENGTH(DMA_RS485_BASE, 8);
IOWR_ALTERA_AVALON_DMA_CONTROL(DMA_RS485_BASE, ALTERA_AVALON_DMA_CONTROL_BYTE_MSK | ALTERA_AVALON_DMA_CONTROL_GO_MSK);
while(1)
if(IORD_ALTERA_AVALON_DMA_STATUS(DMA_RS485_BASE) & (ALTERA_AVALON_DMA_STATUS_DONE_MSK))
for(i=0;i<8;i++)
printf("\n");
for(i=0;i<8;i++)
break;
return 0;
1) Indent your code.
2) The nios cpu is probably repeatedly reading the data from its cache, you need to either invalidate the relevant cache lines or do uncached reads. - Altera_Forum
We solved the problem. After checking the system in Quartus, we saw, that the SD-RAM we used wasn't directly connected with the CPU1. We use an Cyclon3 with 2 CPU and it seems, that this was the Problem. After adding an On-Chip-Memmory and using this, or changing the accessed memmory to S-RAM it worked. For anybody who try to work with DMA and also has some problems dealing with the code, here is our working example without HAL.
#include <stdio.h> #include <stdlib.h> #include <string.h> #include <unistd.h> #include "sys/alt_dma.h" #include "system.h" #include "altera_avalon_dma_regs.h" #include "alt_types.h" #include "sys/alt_irq.h" static int dma_done=0,TX,RX; static void doneDMA(void* context , alt_u32 id) { usleep(10); dma_done++; IOWR_ALTERA_AVALON_DMA_STATUS(DMA_RS485_BASE, 0); } int Init(void) { IOWR_ALTERA_AVALON_DMA_CONTROL(DMA_RS485_BASE, ALTERA_AVALON_DMA_CONTROL_BYTE_MSK| ALTERA_AVALON_DMA_CONTROL_LEEN_MSK| ALTERA_AVALON_DMA_CONTROL_I_EN_MSK); alt_irq_register(DMA_RS485_IRQ,(void*) NULL,doneDMA); return 0; } void Transfer(int where,int from,int howmuch) { dma_done=0; while ((IORD_ALTERA_AVALON_DMA_STATUS(DMA_RS485_BASE) & ALTERA_AVALON_DMA_STATUS_BUSY_MSK)); IOWR_ALTERA_AVALON_DMA_STATUS(DMA_RS485_BASE, 0); IOWR_ALTERA_AVALON_DMA_LENGTH(DMA_RS485_BASE, howmuch); IOWR_ALTERA_AVALON_DMA_RADDRESS(DMA_RS485_BASE,(int) from); IOWR_ALTERA_AVALON_DMA_WADDRESS(DMA_RS485_BASE,(int) where); IOWR_ALTERA_AVALON_DMA_CONTROL(DMA_RS485_BASE, ALTERA_AVALON_DMA_CONTROL_GO_MSK | IORD_ALTERA_AVALON_DMA_CONTROL(DMA_RS485_BASE)); } void MemInit(int base_addr,int len, int value) { int i; for (i=0;i<len;i++) IOWR_8DIRECT(base_addr,i,value); } int main(void) { MemInit((int)RX,0x10,3); MemInit((int)TX,0x10,6); Init(); Transfer((int)RX,(int)TX,16); while(!dma_done); return 0; }
