20 years agoDM9000A net port
I have a question about my ethernet port, the chip is DM9000A
when I download kernel by" nios2-download -g vmlinux" ,then enter as nios2:Uclinux, the netport is ok sometimes, but it's bad sometimes. When the port is bad, I use the list command to display someinformation. Could you please tell me what happened and dow to do? # ifconfig(2006,06,13) lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 UP LOOPBACK RUNNING MTU:16436 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:0 (0.0 http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/cool.gif TX bytes:0 (0.0 http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/cool.gif # ifconfig eth0 192.168.168.2 SIOCSIFADDR: No such device Thank you very much! Best Regards! Feiwu1 Reply
--- Quote Start --- originally posted by feiwu@Jun 13 2006, 03:35 AM i have a question about my ethernet port, the chip is dm9000awhen i download kernel by" nios2-download -g vmlinux" ,then enter as nios2:uclinux,
when the port is bad, i use the list command to display someinformation.
could you please tell me what happened and dow to do?
lo link encap:local loopback
inet addr:127.0.0.1 mask:255.0.0.0
up loopback running mtu:16436 metric:1
rx packets:0 errors:0 dropped:0 overruns:0 frame:0
tx packets:0 errors:0 dropped:0 overruns:0 carrier:0
rx bytes:0 (0.0 http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/cool.gif tx bytes:0 (0.0 http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/cool.gif
siocsifaddr: no such device
thank you very much!
best regards!
feiwu
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16141)
--- quote end ---
--- Quote End --- hi I think u need to download the file system also try to configure the net interface before downloading by changing one line in the : "/etc/rc" file. I hope it will run now ! best regards
