19 years agoDM9000A Ethernet and the 25 Mhz Clock
I realise that the DM9000 chip needs a 25 Mhz clock from a PLL, but I'm confused about how to actually deliver it and handle the other signals. I would think you could use a PLL like so: ...
19 years ago --- Quote Start --- originally posted by benway@Mar 17 2007, 05:49 PM i realise that the dm9000 chip needs a 25 mhz clock from a pll, but i'm confused about how to actually deliver it and handle the other signals.
i would think you could use a pll like so:
pll: sdram_pll port map (clock_50, dram_clk, enet_clk);
which would connect the -3 ns output of the pll to the sdram and the divided-by-2 output to the ethernet chip.
the de2_net example, however, has the following port maps:
// the_dm9000a
.enet_clk_from_the_dm9000a(enet_clk),
.iosc_50_to_the_dm9000a(clock_50),
there is also a pll which has a 25 mhz output, but i can't find a place where it connects to the ethernet chip. if somebody can clear this up it would be much appreciated.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22309)</div> --- Quote End --- In the DE2_NET project, the ENET_CLK signal is generated in the DMA9000A_IF.v file, by using a simple divider from a 50Mhz signal to get a 25MHz signal. I agree that it is better to use a PLL to generate the ENET_CLK signal. So you can probably go with PLL code you have.
