14 years agoDM9000 driver for NIOS2 MMU?
Is the diver dm9000.c in uClinux sources for NIOS2 MMU or only for noMMU?
12 years ago --- Quote Start --- It works on NIOS2 MMU and noMMU. I successfully run it. --- Quote End --- Hi, Do you use the tool sopc2dts? I am having problems with the chip DM9000A. The next is correct? dm9000: ethernet@0x801470 { compatible = "davicom,dm9000-1.0"; reg = < 0x00801470 0x00000004 >; interrupt-parent = < &nios_ii_processor >; interrupts = < 1 >; address-bits = < 48 >; max-frame-size = < 1518 >; local-mac-address = [ 00 00 00 00 00 00 ]; }; //end ethernet@0x801470 (dm9000)
