20 years agoDM9000 could supported by uClinux?
When make menuconfig, I choose the networking supporting, because my altera board is DE II, it's ethernet is DM9000, so I choose the DM9000 in devrice choose. after that. when I using command ...
20 years agohi hippo
I wnat to add "ftpd" apps on my uClinuc OS. When i make menuconfig then occur error info........ [jay@localhost uClinux-dist-test]$ make menuconfig config/mkconfig > config.in make -C /home/jay/uClinux-dist-test/config/scripts/lxdialog all make[1]: Entering directory `/home/jay/uClinux-dist-test/config/scripts/lxdialog' /bin/sh: cc: command not found >> Unable to find the Ncurses libraries. >> >> You must have Ncurses installed in order >> to use 'make menuconfig' make[1]: *** [ncurses] Error 1 make[1]: Leaving directory `/home/jay/uClinux-dist-test/config/scripts/lxdialog' make: *** [menuconfig] Error 2 But i excute "yum install ncurses" and don't install completing.... how to solve installing ncurses? help me !!! thx
