20 years agoDM9000 could supported by uClinux?
When make menuconfig, I choose the networking supporting, because my altera board is DE II, it's ethernet is DM9000, so I choose the DM9000 in devrice choose. after that. when I using command ...
20 years agoI have some advice,but not sure.
you can check your nios2_system.h and dm9000x.c, na_dm9000 and na_dm9000_irq is defined in nios2_system.h,so which should be declared in dm9000x.c . Best Regards! FeiWu
