20 years agodistinction between EPCS and FLASH
I want to know distinction between EPCS and FLASH.IF I use only FLASH memory in my custom CPU,is ok?
20 years ago --- Quote Start --- originally posted by jifine2006@Jun 28 2006, 10:32 PM i want to know distinction between epcs and flash.if i use only flash memory in my custom cpu,is ok?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16497)
--- quote end ---
--- Quote End --- EPCS device is used to store the configuration data (.pof) for the FPGA. It is non-volatile. A Flash can store the configuration data as well as the software which will be excuted by the NIOS processor. This is also non-volatile. If you are using only EPCS: On power-on, FPGA will get configured by the data that you have stored in EPCS device. But you have not stored your software program here. So you need to manually download your program through (JTAG) to get NIOS execute it. If you are using only Flash: On power-on manually configure PGA with h/w image, then it will automatically take-up software program stored in the lash and execute it. However, to configure FPGA with the necssary hardware on power-on with configuration data stored in Flash, you will need a flash controller chip in addition. If you use both: Store hardware image in EPCS device and store software image in Flash. On power on, h/w image is taken from EPCS and software from flash. No manual download is required now. If you want to use flash for storing h/w image also, additionally use a flash controller chip as well. So total 3 chips now. Sincerely, kvm.
