17 years agoDisplay problem with SOPC Builder
Greetings everyone. This may not be directly NIOS-related, but I really need the help so here goes. I am trying to get into NIOS II, however I am stuck at the first step: SOPC Builder. When I t...
17 years agoMake sure there are no spaces in your project path. Also try reducing the hardware acceleration settings for your video device to see if that fixes the issue.
I have seen the issue you have mentioned when the Windows language settings are set to Turkish. The reason behind the language issue is long winded (has to do with the 'I' character in the language) and happens with other software out there. The workaround would be to select some other language like English for example before opening SOPC Builder.
