21 years agoDisabling GP-addressing in generated source code
Hi Everybody, I would like to share some thougts about the way to control when the compiler uses GP-addressing to address global data structures. This is resulted also from a talk with Mon...
21 years agoI don't think so... currently the only thing you can do is to disable GP-addressing for -that- particular variable...
In general if you put some data in some address different from .sdata it is highly probable that the GP addressing will not work... PJ
