20 years agoDisable HAL to reduce memory footprint?
Hello NIOS friends, I am working on a system that requires the time-critical DMA transfer of massive amounts of data between SDRAM and a custom peripheral. I don't want the instruction or d...
20 years agoHi Arjan,
> void useless_routine(void) __attribute__ ((section (“.cache”))); This is fine. > But it keeps generating error messages that I am using overlapping > memory sections. Please provide more detail -- please post the info that squirts out with the error. > So: is there a way to park my small subroutine in on-chip RAM using my main > program (which is copied from EPCS4 to SDRAM at power up) by somehow telling > the linker to do so? You're already doing it ... based on your example, you must have an on chip memory block named "cache". Take a look at your generated.x linker file -- the input section name you put in your C code, section (“.cache”), must match the name of an output section ... otherwise it'll be dumped into .text (see example below). > Or is it wise to start writing a HAL independend program in assembly? It's only wise if you really need to do this to meet your requirements. Otherwise, why reinvent the wheel? ... stick with the HAL. Your idea to jump to a small bit of polling code in on chip memory (leaving the bulk of your code in SDRAM) sounds fine. > you might be interested enough to come up with a bright idea Your idea is fine ... and you're almost there ... don't give up :-) Here's an example. There is an on chip memory named "ocm" in SOPCBuider. All code is placed in SDRAM ... except for the routine "foo": <div class='quotetop'>QUOTE </div> --- Quote Start --- #define POLLADDR 0x10000000# define XFER_DONE 0x01 <span style="color:green">int foo (void) __attribute__((section (".ocm"))); int foo (void) { volatile unsigned char *p = (volatile unsigned char *)POLLADDR; while ((*p & XFER_DONE) == 0) ; return (0); } int main() { foo (); return 0; } </span>[/b] --- Quote End --- Here's the objdump, you can see that .ocm is populated: <div class='quotetop'>QUOTE </div> --- Quote Start --- Idx Name Size VMA LMA File off Algn 0 .entry 00000000 01000800 01000800 00009158 2**5 CONTENTS, ALLOC, LOAD, READONLY, CODE 1 .exceptions 000001a8 00000020 00000020 000000b4 2**2 CONTENTS, ALLOC, LOAD, READONLY, CODE 2 .text 00007110 000001c8 000001c8 0000025c 2**2 CONTENTS, ALLOC, LOAD, READONLY, CODE 3 .rodata 00000090 000072d8 000072d8 0000736c 2**2 CONTENTS, ALLOC, LOAD, READONLY, DATA 4 .rwdata 00001d5c 00007368 00007368 000073fc 2**2 CONTENTS, ALLOC, LOAD, DATA, SMALL_DATA 5 .bss 00000214 000090c4 000090c4 00009158 2**2 ALLOC, SMALL_DATA 6 .sdram 00000000 000092d8 000092d8 000091a0 2**0 CONTENTS 7 .epcs_controller 00000000 01000820 01000820 000091a0 2**0 CONTENTS8 .ocm 00000048 03001000 03001000 00009158 2**2
contents, alloc, load, readonly, code 9 .avl_slave 00000000 04000000 04000000 000091a0 2**0 CONTENTS 10 .flash 00000000 0f000000 0f000000 000091a0 2**0 CONTENTS 11 .comment 00000891 00000000 00000000 000091a0 2**0 CONTENTS, READONLY[/b] --- Quote End --- I hope this helps. Regards, --Scott
