21 years ago
difficult software problem
hello,
i use QUARTUS 5.0 NIOS 5.0
i have a difficult software problem, i think something is writing undefined
into memory, but i cannot find it (searching now for two days).
in the main function i have the following...
main() {
int ctime=0;
int ctimemax=0;
while(1) {
if(....) {
ctimemax=1000;
else {
ctimemax=5000;
if(ctime>ctimemax) { // at this point ctimemax is e.g. 0 or something undefined
i have seen that the register fp (which is used to access ctimemax,stw r2,20(fp),
is different from startup, when the error happens.
the main problem is, that if i insert or renmove some code elsewhere,
i cannot see the error again.
one problem i have seen is that i made a fault with timer interrupts,
but i don't know if this could cause the error.
i had a# define
# define ALARMTICKS(x) ((alt_ticks_per_second()*(x))/1000)
DWORD alarm_spst_callback_10ms (void* context) {
alarmflags|=ALARM_SP_10MS;
if(led_txrx_time>0) {
led_txrx_time--;
PIO_CBI(PIO_LED_BASE,LED_TX_RX);
else {
PIO_SBI(PIO_LED_BASE,LED_TX_RX);
if(dsptimeout) dsptimeout--;
return ALARMTICKS(10);
this inserted a multiplication and division in the interrupt
0x00806874 <alarm_spst_callback_10ms+160>: call 0x80c524 <__mulsi3>
0x00806878 <alarm_spst_callback_10ms+164>: mov r4,r2
0x0080687c <alarm_spst_callback_10ms+168>: movi r5,1000
0x00806880 <alarm_spst_callback_10ms+172>: call 0x80c504 <__udivsi3>
i changed this to get a constant for the return value,
i cannnot see the error in the main loop again,
but i think this was not the problem
could the multiplication and division in the interrupt cause my problem ?
any suggestions, how i can find this error ?
i have seen that there is now "Run time stack checking", how does it works?
thanks
