22 years agodifference between main() and alt_main() ?
My customer NIOS2 config is : cyclone 1C20, SDRAM, EPCS4. And SDRAM memory base is locked at 0x0. Reset address and Exception address is set to SDRAM. When I debug hello_led.c in my board, progr...
22 years agoOoops make that should not. If you don't understand alt_main you probably should not be using it
