20 years ago
Difference between booting from onchipmem and cfi?
everyone
Having done the step 1-3 successfully, I will do sth. else:
Then more fun:
CompileHello
FlashProgrammer
EPCSGuide
EtherNet
NFSFileSytem
CompactFlash
AlteraPCI .
UsbHost.
ModuleProgarmming
BuildrootGuide
BusyBox
KernelPatches
CustomBootLoader
Mpeg2Dec
MmcSd
When doing "FlashProgrammer " ,I have a question:
what are the Differences between booting from onchipmem and cfi?
Thanks!
    in sopc builder, more cpu setting, reset address
    this is the hardware reset entry point
    a. if you set it to cfi flash, it will insert a altera supplied cfi boot loader by default, then load your program image to sdram, and jump to sdram.
    b. if you set it to epcs, it will include a hidden onchip memory, with altera supplied epcs boot loader,
    which will load your program image to sdram, and jump to sdram.
    c. if you set it to onchip memory, then you need a custom boot loader on the onchip memory, which should load your program image to sdram. eg, you can store your image on IDE HDD, etc.
