16 years agodhcpcd problem with 3c120
I use a reference design for embedding linux to 3c120 dev board. I tried with reference design with MMU and No MMU. Both has failed to get dynamic ip with dhcpcd command. With these designs ethernet lights lit and when i give static ip, no ethernet activities occure. i am appriciate for your help1 Reply
I have the same problem with you, also on one 3c120 board. When I use dhcpcd to get dynamic ip, it failed. It seems that if I change to use static ip, everything works fine. Anyone has any idea on that? Thank you!
