16 years agoDHCP superloop mode
Hello! Well, I'm facing this issue. Internichestack in superlop mode works correctly, DHCP too. The problem is this: when turning on the module, without ethernet cable connected, the DHCP clien...
16 years agoThe application selector application, shipped with the NEEK and 3c120 dev kits, has a task which monitors the autonegotiation successful bit in the PHY. Something similar could be done in superloop mode. The concept would be to hold off stack initialization until successful PHY autonegotiation.
- slacker
